Smart Hub Pro SH4-1 Firmware Revisions
mikefairgrieve
Currently my Smart Hub Pro is sitting at the below App and Firmware versions, anybody's updated to anything newer?
App version:
2.34.2
Firmware version:
r2.64.3-R-1213091-PROD-1
10 REPLIES 10
Maestro
Maestro
@mikefairgrieve Nobody of the Pro fraternity has posted anything higher than what you have, so assume you are on the latest.
mikefairgrieve
Updated 04/02/25 - Not noticed any changes.
App version:
2.34.2
Firmware version:
r2.64.5-R-1298597-PROD-1
@mikefairgrieve It may possibly be the fix for the midnight update check causing the router to hang for a short period, worth checking that. Known issue's wither reported not sure, Ethernet port connection delay, DDNS screen connecting, Extender screen wired backhaul display's 1000 should do 2500. Just a few but who knows, what and the Midnight test check hang.
mikefairgrieve
2 that i can confirm are unchanged, i am on the 900Mb package so didnt experience any midnight connectivity issues.
  • DDNS Status - Unchanged as still shows "connecting"
  • UPNP - Still broken
Huggons1
The fixed channel bug hasn't been resolved in r2.64.5-R-1298597-PROD-1 either.
bigsteve47
The smart hub pro is absolutely garbage..multiple dropouts per day...
mikefairgrieve
Updated Hub and Extender again - 07/02/25
App version:
2.34.2
Firmware version:
r2.64.7-R-1303938-PROD-1
Huggons1
Just received it at around 03:00 this morning too
Huggons1
r2.64.7-R-1303938-PROD-1 still hasn't addressed the fixed WiFi channel bug.
