27-03-2024 02:09 AM - edited 27-03-2024 02:29 AM
Just noticed my Hub updated from:
Firmware version: r1.29.0-R-950306-PROD-83002
GUI version: 1.11.0
To:
Firmware version: r1.34.0-R-994210-PROD-83002
GUI version: 1.13.1
Let's hope it feels like less of a beta product now!
Update 1: Just factory resetted the Hub for some quick testing, the UI is still slow initially and still gives a [CHOP3-800] error but does feel a little faster afterwards, VoIP also seems to connect faster
on 03-04-2024 01:06 PM
The only visible GUI change I noticed on the router with the newest 1.13 firmware is that they fixed the styling for the list of devices connected to the router which I posted about back in February - https://community.ee.co.uk/t5/Broadband-Landline/Router-page-css-messed-up-was-an-update-rolled-out/...
There might be more behind the scenes but that was the only obvious one to me.
on 03-04-2024 01:12 PM
@monitorcurve : Oh, yes, I never encountered that but I never had any intermediate versions between 1.9.0 & 1.13.1.
on 03-04-2024 01:29 PM
Ah that makes sense, I'm trying to make a timeline list of the firmware/gui updates that have happened in the past 12months, and I that css error was in the middle of those 2 updates:
Firmware version: r1.29.0-R-950306-PROD-83002 06/02/2024 App ver 1.11.0.on 18-04-2024 08:39 AM
No cure for web controls.
on 22-04-2024 04:32 PM
GUI version: 1.13.1
Still Buggy, Digital Voice Issue where you can't hear incoming calls and when you call out sounds like you dial-up you after restarting Hub and ONT just get Digital Voice back I have tried flagging it With New EE and they don't seem to care about the issue pass you to different team
on 31-12-2024 08:49 PM
Can I ask what firmware version people are on now using EE smart hub plus router
I am on Firmware version: r1.35.0-R-1138091-PROD-83002 17/08/2024 App ver 1.13.1
Cheers
31-12-2024 11:03 PM - edited 31-12-2024 11:04 PM
As of 31st Dec 2024, mine is on :
App version: 1.13.1
on 31-12-2024 11:06 PM
Thanks. Looks like others are getting Smart Hub Plus router (SH31B) updated to...
on 04-01-2025 09:57 AM
smart Hub pro App version:2.34.2, and Firmware version: "r2.64.3-R-1213091-PROD-1"
on 06-01-2025 10:09 AM
@UkzVortex98 I imagine that the next Pro firmware version will be "r2.68.11-R-1213091-PROD-1" as the GUI for both the Plus and the Pro are very similar
