31-05-2025 08:46 PM
Hi. I just had Openreach install my new line for the 990mpbs package. Speed is rubbish. After the first day which was close to the correct Speed, it now fluctuates between 60 - 990.
I noticed that a car drove over the cable while the engineer was installing. Could that have caused the Speed issues?
Any suggestions welcome. I will give EE a chance to sort this out before I cancel.
01-06-2025 10:34 AM
01-06-2025 10:43 AM
Smart Hub 2023 no extenders or mesh. Just the router
01-06-2025 10:51 AM
@ddemolder And have you come from BT with that as a replacement Router, or you have always had that one!
01-06-2025 11:52 AM
Yes I moved from bt and it's a new router
01-06-2025 12:19 PM
@ddemolder Thought that when you posted, all you can do is keep an eye on what is going on the external fibre cable is kevlar coated protection and is very strong so hard to say but you cannot discard as a potential problem, and you need to set up a standard for a test, if you cannot do a network ethernet test then fighting wireless wi-fi is always going to be difficult...
Have a read at the link when you get time.
01-06-2025 06:52 PM
I tried ethernet speed test. It was 360mbps. Spoke with EE who said that I am receiving 990 to my router.
01-06-2025 06:56 PM
It's not just the speed of a speedtest but the shape!
01-06-2025 06:58 PM
Thanks but I don't know what you mean
01-06-2025 07:01 PM - edited 01-06-2025 07:01 PM
Had you followed my instructions for the speedtest I might have been able to comment further.
01-06-2025 07:21 PM
@ddemolder Request after you posted is about the speed test request. Can you do it and link your result!
