Slow Full Fibre 100
Rooneyj
 Hi, I am.experiencing very slow download speeds across both wifi & wired connections. I would appreciate any support in fixing this issue.  thanks.
7 REPLIES 7
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
Was that speedtest done wired?
Rooneyj
wired.
Leanne_T
Hi @Rooneyj
Thanks for coming here.
I would suggest reporting this to our Broadband Care team, they will be able to get this looked into in more detail for you.
Leanne 🙂
As a sanity check would you post the Home > Status page of the router?
Nivag80
Do you know a New cusomter on Fibre 100 Max who has never been with EE is going to be paying a lot less than you come April 1st
