04-01-2023 05:57 PM
In EE smart hub manager - Home / Advanced settings / Access Control.
I wish to add a new start time / End time restriction for a device. Once done I get a "changes need to be saved"
However, once the save button is clicked nothing happens...
04-01-2023 09:59 PM - edited 04-01-2023 10:00 PM
After you selected the device & chosen times did you press the '+' on the R so the entry got moved to below the line? If not, show image of page once the Save is clicked.
05-01-2023 09:28 AM
Yes I did press the "+" button and the entry does get moved below the line.
Once done I get a "changes need to be saved" but when the save button is pressed nothing happens
05-01-2023 01:15 PM
Hi @Ss106
Thanks for coming here.
Have you tried restarting the router then trying to change the settings?
05-01-2023 01:48 PM
Yes done that too Leanne, but was still producing the same issue.
05-01-2023 01:52 PM
Thanks @Ss106
In this case, please call us on 0800 079 8586 and the team will get this looked into for you.
05-01-2023 02:18 PM
I did delete 2 devices which were already listed and that seemed to have unlocked something as I managed to add a new device. It should not be number related so I doubt that this was the issue but in any case it now works...
05-01-2023 02:29 PM
Thanks for letting us know @Ss106
Leanne 🙂
