09-09-2024 01:36 PM
I would like to replace my hub that came with EE and use the ASUS DSL-AX82U i am on the Fibre plus plan. as i would like to use a vpn built into the router would this be compatible?
09-09-2024 02:43 PM
@Kathrynday123 yes you can use your own router, in fact I have the same one.
EE have a handy help page for the settings:
https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
specifically :
| Connection type: | Point-to-Point Protocol over Ethernet (PPPoE) |
| Broadband username or login name: | [email protected] |
| Broadband password: | BT (or leave blank) |
| Authentication: | CHAP |
| DNS: | Auto or Obtain from ISP (we'll automatically provide these when you connect) |
| VLAN: | Active |
| VLAN ID (802.1q): | 101 |
| VLAN ID (802.1p): | 0 |
Let us know if you have any issues.
09-09-2024 01:42 PM
09-09-2024 02:43 PM
specifically :
| VLAN: | Active |
10-09-2024 03:03 PM
I have seen that because i have the white SH that i wouldn’t work is that correct?
10-09-2024 03:05 PM
@Kathrynday123 no, you just replace it with your Asus.
05-11-2024 09:34 AM
I have just got my router i set it all up but it has no internet connect so i reset it and im gonna attempt again today please can you help
thank you
05-11-2024 10:05 AM
@Kathrynday123 what is happening, I thought you had this all sorted?
05-11-2024 10:18 AM
i only received the router yesterday i was previously asking all them questions to see if i should buy it
05-11-2024 11:14 AM - edited 05-11-2024 11:14 AM
Post the WAN/Internet Settings page of your router.
05-11-2024 11:41 AM
@Kathrynday123 how far are you getting, and are you using the quick setop or trying to do it the long way?
