Red flashing light
ARMandrew1
  • I have a continuously flashing red light on my broadband, not getting internet access, all my devices are currently not working, tried all the possible solutions of turning off and on what is the issue at the moment?
Hi
Thanks anyway, problem now solved.
7 REPLIES 7
ARMandrew1
Hi
I’ve only just woken to find a flashing red light on the router apparently it appears to be the Internet connection that is flashing having tried turn off the router for 20 seconds it is still continuously flashing is there  maintenance issue again?
ARMandrew1
What’s going on? Red light flashing no internet connection EE needs explain quality of service as it has had issues  within the last few weeks not getting connections and disconnected from Internet service.
@ARMandrew1 : It would help to say which router.
Hi
It’s not the router, the router works fine, it’s the internet connection
from EE flashing red.
OK, the light is on the router, is it not? I'm not saying there is anything wrong with the router. It's meaning will depend on which router, but I'll leave it at that.
Hi
These things occasionally happen, particularly overnight or weekends. It could be that an OR eng has accidentally disturbed your line while working at exchange or cab. It's usually back by mid-morning at the latest w/out EE even being aware of it.
