Re: Whole Home Broadband
Northern_Smithy
Do you know if BT Discs (white ones) will work with the new EE router.  Just flipped to EE from BT and dont want to swap out equipment until I know as I have 4 discs in the house/garage/office for full coverage and only received 1 extender from EE
Ive queried this forum and couldnt find an answer.  I imagined it might have been a popular question 🙂
Thanks in advance !
@Northern_Smithy : If you have the EE Smart Hub Plus ( SH31B) (SH+) router, the white "high st." Whole Home discs do work with the SH+. It's the black BT Complete WiFi discs that don't!
Thanks XRaySpeX - superfast 🙂
Gonna try the lift and shift tonight then 😉
Last time I kept my SSID and PW so all the devices just rollover, assume that will work again.  If you've additional tips please share
Thanks again !
The router's PPPoE BB Username & pwd will be the same as for BT.
Sorry I forgot to reply.  Yes your option worked perfectly thankyou again !!
