09-08-2025 07:32 PM
Printed at good speed on BT Hub (15 secs) - on EE Hub slows to a crawl (5 minutes).
Epson ET-2820 connects via wi-fi to laptop.
Switched EE to 2.4Ghz only. No change.
No spare slots on printer for ethernet cable - only one to my PC, everyone else uses wi-fi.
If EE Hub / printer connection cannot be fixed, will need to bin EE Hub and plug old BT Hub back in (seems a bit of a backward step, but if it works, it works).
Any idea on how to get the E Hub/printer working?
09-08-2025 10:01 PM
@pauldurrant What EE router do you have?
10-08-2025 09:52 AM
Smart Hub Plus
10-08-2025 10:52 AM
What is the name of the EE BB plan are you on including its speed?
10-08-2025 11:11 AM - edited 10-08-2025 11:12 AM
@pauldurrant You may just have to setup the compatible wireless on the EE Router to cover the printer needs! Link below will help!.
10-08-2025 06:54 PM
Darn - no luck either ....
10-08-2025 06:55 PM
Fibre 67 All Rounder
10-08-2025 06:57 PM
Guaranteed download speed is: 57.7Mbps
64 - 71 Mbps estimated download speed
16.6 - 18.4 Mbps Your estimated upload speed
10-08-2025 07:19 PM - edited 10-08-2025 07:40 PM
@pauldurrant What is the WPA mode that you used! Below what the printer supports! Would use the last WPA2-PSK!
WEP 64 Bit, WEP 128 Bit, WPA PSK (TKIP), WPA2 PSK (AES)
ET-4800 Series L5290 Series ET-2820 Series L3260 Series Page 271 for spec, 2.4Ghz only.
10-08-2025 07:25 PM
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
