Pairing bt wifi phone to ee
Hidz44
Hi there. Just had my ee broadband. Everything set up fine but my bt wifi cordless phone won't connect automatically. Could someone help me how to do it. I tried but still wont work. Or is it really impossible to pair bt phone to ee hub? Thank you
@Hidz44 : Have you plugged it into the phone socket on the router or the adapter?
webweald
did you find a solution?
Mustrum
@webweald  As you can see the OP never replied, nor did they give much detail to their problem.
If you would like to explain what problems you are having, with as much details as you can, we may be able to help.
