02-06-2026 12:14 PM
I've just switched to EE and at the same time upgraded my BB speed to 900mbps, I have 2 PC's on wired connection but when I run a speedtest one of them gets 900+ as the download speed and the other only half of that. I've tried all of the suggestions that I could find on google but no change. The PC has 2 different built-in LAN ports and I've tried both, updated drivers , changed parameters but still only half speed. I've also tried different cables, router ports (It's a TP-Link AX3000) nothing works although one speed test did actually show 900+ but then reverted after a reboot. As the PC is quite old and as a last resort I bought new USB3 to Gigabit converter but still only get half speed.
I'm open to any suggestions as to what to try next
03-06-2026 08:56 AM
@AlanFretten May be help full for you.
03-06-2026 12:47 PM - edited 03-06-2026 12:53 PM
An internet speed test from a PC is a quick way to check everything is fine but not good for fault finding. A test to router (so no LAN/WIFI/PC involved) would point to a ISP Router/ONT/OR issue such as a speed upgrade not happening - but as you've already moved on to testing data transfer device to device on the LAN it's best to be looking at LAN speed test apps and not internet speed test results.
The main requirements for W11 are a compatible processor - a 6700K or older isn't OK for example, a GPT format disk and CSM off for UEFI boot, and TPM - just a BIOS setting such as PTT for Intel. I wouldn't recommend work-arounds as one day they will cause a compatibility problem - but not something like a low transfer rate.
As before, after checking for any unnecessary background apps, and assuming the LAN driver is up to date and at default settings, and the cable and both the PC and LAN ports arent broken, I'd normally just do an in-place re-install (the fix problems with Windows Update option in recovery settings) - it's fairly quick and brings things back as they were - but I'm not sure what happens if the PC is not W11 compliant.
