07-05-2024 06:47 PM - edited 07-05-2024 06:52 PM
About 5 weeks ago we switched from BT to EE for our Broadband and TV. Starting to regret that decision. We were sent a new router, a new TV box and 3 WiFi plus boxes. This is the same equipment we had with BT for many years. Over this period we hardly had any issues and I was always able to speak to someone if I wanted. Oh how have things changed!!. We've been having ongoing problems and it is impossible to speak to anyone! When you phone them, you just get connected to a fault Bot and you end up in a loop. I've started to keep a record of the issues but generally the same problem. Over the last ten days, our WiFi has gone off during the night on six occasions. On the following mornings, nothing connects to the internet. The connection to the Ring doorbell, our thermostat, the TV, all our mobile devices, our work computers drops over the previous night. Weirdly, you don't realize initially because the router remains blue. The TV has an error IPC6023. Our phones advise that there's no Internet despite also stating that that we have an excellent signal. Unplugging the router and plugging it back in generally solves the issue but I shouldn't have to do this every other day! I've raised a complaint now but not holding my breathe. Starting to think that EE's equipment is substandard compared to BT.
24-07-2024 09:06 AM
@TT230968 The BT router will work on the EE Broadband service, so as you suggest changing back you have to do as you did with passwords etc. There are a couple of unknown's so see if they apply to you, DV for the landline, is it like for like BT/EE. The BT router has to be managed now with the EE app, and there was a problem with parental controls, but the app is upgraded all the time, what works/breaks etc will only be known with customer complaints. Your problem may be down to possible settings on the new EE router with regards to the laptop not liking something in its settings, they are not apples to apples... If you wish to try few setting changes they may possibly help, otherwise you can just put your old BT back. Understand the pressure of having it working with no issues. If asked to return BT equipment, then advise you to contact EE to let them know what you decided to do. HTH
24-07-2024 09:18 AM
24-07-2024 09:45 AM
@TT230968 No problem if you need any help just post back, do let us know which way you are going, the EE router is fairly good as ISP equipment goes, smart wi-fi boosters may take a little time to settle, but it is hard to determine what is going on with regards to when a device decides where it is going to connect to, colour of lights on both may indicate. See few instance of BT good, EE bad but it is not really or can be the case. BT router does have a good spec, and if it was working well do understand, not sure how the EE support goes with regards to help, but EE/BT guides are to be the same, so you may have to get the BT knowledge if you need that help. Hope it goes smooth for you.👍
24-07-2024 10:03 AM
24-07-2024 10:15 AM
@TT230968 It all does take a little time for everything to gel together, DV switch over app/account's etc, this may be the case for you, were you auto migrated to EE from BT, or just advised to go there at the end of your contract? Your landline was it also plugged into your old BT router you need to check this as some older BT routers did not support landlines so may be possible that you had to get the EE router, you may have gone to DV now, OR are now automatically changing customers especially under new contract conditions, when i was with Sky they tried it with me, and i just said NO WAY, there are far to many issues at present and i rely on the landline working as it was due to personal circumstance.
24-07-2024 10:24 AM
24-07-2024 10:44 AM
@TT230968 I would call EE CS and explain your situation, request that they send an EE Guide as you are now in a bad condition with regards to not having it all working, and see if they can sort it all out for you. If they cannot fix it, at least the will be able to put your BT back on for you. IF your laptop has an ethernet port and you have a cable spare you could try plugging it in may get you going short term quickly at least to work. Good luck with it all.👍
02-08-2024 09:26 PM
Very disappointed to see this thread. BT contract came to end so when renewed told it was EE now and installed new equipment yesterday. Worked mostly from home since 2020 never had an issue. Now keeps dropping out, Teams meetings failing and simple TV streaming not working. Absolute rubbish so will terminate if they don’t sort this week.
02-08-2024 09:54 PM
@Twitchie If you still have your BT equipment and feel comfortable at putting it back, you can do so to get you out of hole at present. Original OP would have had some trouble trying to do it, so advice was to get help from EE.
06-08-2024 03:12 PM
I am glad that I found this and many other community forum chats about the EE hardware, I have stayed on my existing BT Smart Hub 2 and extenders for the past 4 weeks since the switchover to EE broadband and everything works fine, with no drop in broadband speed/lagging. The only thing I updated was TV Box to EE (into my BT router).
I called EE and they did insist I try the new router etc but understood that I was concerned about the numerous issues on EE smart hub plus so accepted that I would return the new EE hardware and old BT TV box. They asked that I keep in touch and of issues occur to request a router then - but I think there's a better EE router in development,
Thanks to all contributors on EE and BT forums for the intel.
