on 17-11-2024 09:46 PM
I have signed up today to switch from sky to ee and received a small to say I have to setup my openreach modem but I don't have one. They are sending me the smart hub plus, can I connect it directly into my little BT box, as u do now?
17-11-2024 10:47 PM - edited 17-11-2024 10:49 PM
Depends for what BB plan you've signed for. What is it called including its speed.?
You only need an ONT modem for Full Fibre (FTTP). It it's that EE will be sending an OR eng. to install it.
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
on 18-11-2024 01:56 PM
on 18-11-2024 01:59 PM
I'm asking you what you signed up for?
on 18-11-2024 02:16 PM
on 18-11-2024 02:22 PM
What was the BB plan called?
on 18-11-2024 02:33 PM
18-11-2024 02:47 PM - edited 18-11-2024 02:47 PM
That is Fibre to the Cabinet (FTTC) & then a copper landline to your home. It doesn't have an OR ONT modem. The SH+ router incorporates the necessary VDSL modem.
