10-04-2024 05:27 PM
Hi, since going onto the new digital home phone (which goes into the back of the router) my extension upstairs doesn't show any caller id which isn't very good as we get lots of scam calls. The phone downstairs which is plugged into the back of the router does still show who's calling. Oh I have also forgotten to mention that the extension upstairs is plugged into a EE adapter. Is there anyway around this and getting the id back?
Chris.
11-04-2024 06:07 PM
Yes that is correct, both phones downstairs have not not upstairs.
I will try pairing the adapter again I presume just by unplugging it?
11-04-2024 06:23 PM
What router do you have? Usually you login to the router via a browser, enter 192,168.1.254, and click on you telephone no. You should be able to remove the adaptor from there.
11-04-2024 06:43 PM
Just reread your last post just to confirm does this “both phones downstairs have not not upstairs.” mean that both phones don’t ring upstairs?
if yes do you have a spare ADSL filter, that use to plug into the master socket to split phone and broadband. Plug this into the adaptor and the plug the phone into the filter.
11-04-2024 08:46 PM
Both phones ring up and downstairs but when downstairs both phones have caller id but both phones when upstairs don't have caller id it just says Call.
And yes I do have a new adsl filter plugged into my ee adapter with my phone cable plugged into that.
11-04-2024 08:55 PM
Does the phones ring without the filter?
11-04-2024 10:09 PM
Yes, both do.
11-04-2024 10:19 PM
Does Caller ID work without the filter?
12-04-2024 12:00 AM
Only downstairs on both phones.
12-04-2024 08:53 AM - edited 12-04-2024 08:55 AM
I’ve not seen this Caller ID problem mentioned here or on the BT community, the usual one is that the phone won’t ring and using the filter on the adaptor allows the phone to ring.
Have you tried the re pairing the adapter to the router?
I’d call customer services and see if they will send a replacement adapter to see if the first is faulty.
12-04-2024 02:09 PM
I've just re paired the adapter but the same thing happens.
I give up but the most frustrating thing is i just had to answer the phone which turned out to be a scam call which woke me up as I didn't know who is was calling.
