No broadband after power cut
JW8114
We had a power cut this morning and since then I can't reconnect our WiFi. I've tried all restarts including factory reset but it just has a green light and every 30 seconds or so a quick white flash then back to green. Can anyone help please?
19 REPLIES 19
If you have Full Fibre (FTTP), what lights show on the ONT?
Maestro
Maestro
Essentials Fibre 36
Essential Fibre 36
Green light but every 30 seconds or so quick flash of white then straight back to Green.
@JW8114 see the link to what the lights mean and if any off it applies let us know.
Manage Your EE Hub | Broadband Help | EE
That's continually trying to start up. Looks like it's not completely broken but is frazzled. Call CS & ask for a replacement router.
Yep, whatever I try to do it just keeps on with this pattern 😔. Thanks
@JW8114 When you did the factory reset did it look like it followed when holding the button until the front light changed colour or just kept doing what it is doing, green/flash white etc?
Kept doing what it was doing after holding down for 20 seconds
