New Pro Firmware r3.8.24-R-1531355-PROD-1 for router and extenders.
tnj
Skilled Contributor
Skilled Contributor
This morning there is new Pro router firmware r3.8.24-R-1531355-PROD-1 and it starts by saying use HTTPS which is then says is not available. It then requires the admin password to get into any level of access. Now testing out what it does.
It allows you to set your own DNS servers in DHCP.
It still does not let you lock the 2.4G WiFi to a channel, it keeps reverting to Channel 11
145 REPLIES 145
Colesey
Mines updated. Must say this update seems to improved stability a lot and
backhaul issue seems to be resolved.
Full Fibre Gigabit
Smart Hub Pro
smneal
Waiting for mine to get updated too. It’s been up for a few days and no firmware change so far.
Z86
Ok ty! Just for curiosity last night I plugged in my Smart Hub Plus for the first time, that came with my 900mbps package, and that updated within the hour.
So I was worried that because my SH Pro was bought from Ebay that it was blocked or something. Nice to know that it's probably just a slow rollout instead xD
Community Hero
Community Hero
@smneal It's a waiting game, there is nothing you can do but ensure that the EE Router is up all the time, EE have lot's of pushing out to get through!
@Z86 same as above, looks like it should get as others in the same position as you have received, don't think EE are serial number applying to much at the account level yet!
Colesey
I believe another member of the forum got there’s from EBay and there’s
updated 👍🏼
Full Fibre Gigabit
Smart Hub Pro
Ewan15
Expert Contributor
Expert Contributor
@Colesey  Mine updated last night. Lets see if it is an improvement
Swf-uk
Not related to networking, but if anyone is using the inbuilt DECT hub then it is now possible to change ring tones on connected phones successfully.
Community Hero
Community Hero
@Swf-uk Ringtones NO LONGER work!
Not my experience? With the previous build I was unable to change tones, with the new it works, I’m using 4 x BT Advanced phones (with Alexa that doesn’t work) change the tone on one phone and all pickup the change.
Community Hero
Community Hero
@Swf-uk There is an EE Product specialist so hopefully he is seeing this and will reachout to you when he can!
