24-01-2025 10:22 AM - edited 24-01-2025 10:25 AM
Hi
When connected to the internet through EE router I get the error message when going onto Netflix "you seem to be using a VPN or proxy". This happens on iphone, ipads, apple TV, Windows PC.
If I connect on mobile data it works fine. If i connect though a UK VPN it works fine
I turned off the router for 30 mins and also factory reset the router to get a new IP address and it still happens.
Any ideas?
Before you say reset you Iphone or reinstall the app it happens on every device 🙂
25-01-2025 11:48 AM
I can only report what is happening.
My primary profile gets a VPN block on Netflix, other profiles do not Bizarre
25-01-2025 11:49 AM
It's no longer a problem. All working
19-01-2026 03:45 PM
Hey, I know this is a year late, but I'm currently having this issue right now. However, it's on all my accounts. I've contacted both Netflix and EE, but no help. It still doesn't work. I was wondering what you did to fix it so I could try.
26-01-2026 08:50 PM
