28-07-2019 07:21 PM
I have a smart hub and a bright hub 2. I want to link them together. Ee say it’s not possible. Is this true?
26-01-2022 01:52 PM
i have linked 2 routers with an ethernet cable the main one in the house and an identical one in the mancave in the garden which runs perfect and i have wifi and run a ps4 pro driving set up with no problems
26-01-2022 01:54 PM
i did the same works no problem
26-01-2022 01:59 PM
@michaelmaclean : Well done! As a matter of interest, what routers are they?
26-01-2022 02:30 PM
2 ee smart hubs one i got from with my broadband and the other i got from ebay
26-01-2022 02:30 PM
both the same
26-01-2022 03:08 PM
Hi @michaelmaclean ,
For the downstream router in the mancave, did you choose to connect the Ethernet cable up to the WAN/internet port, if one exists, or to one of the downstream router LAN switch-ports?
27-01-2022 12:35 PM
hi i have it from the WAN port to the WAN port and it works fine
27-01-2022 01:14 PM
@michaelmaclean : They are not WAN ports unless the setting WAN port is ON on the Advanced Settings / Broadband / Internet page. Are they both or which 1 is?
27-01-2022 01:21 PM
hi mate im not sure what i did im not a expert in this lol but i messed about untill i got it to work both in the house and the outside bar both work fine with wifi in both
27-01-2022 01:27 PM
@michaelmaclean : OK, so you are unable to answer @mikeliuk 's Q.
