22-04-2022 10:54 PM
We've just moved in to a new build and openreach have connected us today. Now BT will offer us fibre broadband but the EE system returns an error. Is this just a timing thing or will I have to sign up for a BT connection before I can switch to EE?
22-04-2022 11:10 PM
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
23-04-2022 06:50 PM
Merely timing. If the install only happened yesterday then the info needs time to populate throughout the different ISP's onto their websites. If you ring in though the ISP's have the info at the same time.
A tip, if you ring in then have the ONT serial number to hand as that is what registers the service to the property.
