Latest smart hub pro firmware?
Appleaday
Mine updated overnight to this
r3.8.26-R-1595999-PROD-1
7 REPLIES 7
Maestro
Maestro
@Appleaday That appears to be the latest currently.
FW: r3.8.26-R-1595999-PROD-1 and the gui is at App Version is 3.1.3.19 24/12/2025
FAM0422UK
Mine is currently r3.8.24-R-1531355-PROD-1)
should it update to yours? Can you trigger a update or is it phased out?
tnj
Skilled Contributor
Skilled Contributor
It will come to you when they decide to release it, there is nothing you can do to change when you get it.
So far it seems that it is recently sent out hubs that have had this update. I have been on the previous version since September.
Colesey
I’m still on r3.8.24-R-1531355-PROD-1
Is there deffo a new version available?
Full Fibre Gigabit
Smart Hub Pro
@Colesey See the link below and as far as EE are concerned what you have is the latest and did not require to be FW updated any higher than you have!
Solved: Smart Hub 7 Pro Firmware not updated to the latest version - Page 2 - The EE Community
tnj
Skilled Contributor
Skilled Contributor
r3.8.24-R-1531355-PROD-1 is the still the current firmware release for older hubs and a minor upgrade version was released for newly dispatched hubs which only concerned their initial set up. It's been a long time waiting for fixes.
@JimM11 : It's no good posting links to particular pages of a thread. Everyone will have diff page sizes. Use the Permalink feature instead to point at a particular post.
