Smart Hub 7 Pro Firmware not updated to the latest version
NealB71
Cauld someone please advise why my Smart Hub 7 Pro has not updated to the latest firmware?
The Web UI and EE App both state that my hub and 2 extenders firmware versions are r3.8.24-R-1531355-PROD-1 and I know there have been at least 3 updates since this which the latest being FW: r3.35.24-R-1648110-PROD-84001.
The reason I am asking is due to not being able to set a static IP of my choice to any of my devices, which the latest firmware version is supposed to fix.
Is there anyway to force the update or update the hub and extenders manually?
Any help would be gratefully appreciated.
25 REPLIES 25
Linzi_H
Hi @NealB71
I'd love to have this double checked with our support team for you. I'll send over a Private Message so I can take a couple more details.
Linzi
tnj
Skilled Contributor
Skilled Contributor
Linzi, it might be useful to report back here as I don't think anyone who has had the Pro router for more than a few months has received the latest firmware updates.
Huggons1
My smart hub pro last received an update October 2025...
App version: 3.1.3
I've had my Smart Hub Pro plugged in since December and mine is also stuck on:
App version: 3.1.3
Firmware version: r3.8.24-R-1531355-PROD-1
A factory reset didn't help.
Linzi_H
Hi everyone.
I have been in touch with our support team, and they have confirmed that r3.8.24-R-1531355-PROD-1 is currently the correct firmware version for the Smart Hub 7 Pro. Later version numbers apply to other Hubs or new activations.
When your router is due a firmware update, it will be automatically pushed through as expected.
I hope this helps,
Linzi
tnj
Skilled Contributor
Skilled Contributor
I am curious as to why new activations get a later version of firmware?
@Linzi_H That just does not make any sense at all, has there been a Hardware change to the now EE Smart Hub 7 Pro version (New Name) that requires a different version of FW applied?
Linzi_H
Hi @JimM11 @tnj
It isn't related to hardware. We needed to make a small change to the firmware, specifically for the setup process for newly activated routers. Routers that were already activated didn't need this change. The difference in current firmware versions between the routers is minimal.
As soon as a firmware update is required, it will be rolled out automatically.
Linzi
@Linzi_H Thanks that's way more informative, you would have them all jumping up and down going nuts!
All looking at this list is below for the Current/New Purchased FW to expect when connected to the service....
FW: r3.8.24-R-1531355-PROD-1 and the gui is at App version 3.1.3. 17/09/2025 Now https://  Current for all that are not the latest see the post from @Linzi_H above.....
FW: r3.8.26-R-1595999-PROD-1 and the gui is at App Version is 3.1.3.19 24/12/2025 New Hubs will update to this version when first connected, minimal change so not a major from the previous!!! also see @Linzi_H above....
