22-02-2026 12:25 AM - edited 22-02-2026 12:31 AM
Cauld someone please advise why my Smart Hub 7 Pro has not updated to the latest firmware?
The Web UI and EE App both state that my hub and 2 extenders firmware versions are r3.8.24-R-1531355-PROD-1 and I know there have been at least 3 updates since this which the latest being FW: r3.35.24-R-1648110-PROD-84001.
The reason I am asking is due to not being able to set a static IP of my choice to any of my devices, which the latest firmware version is supposed to fix.
Is there anyway to force the update or update the hub and extenders manually?
Any help would be gratefully appreciated.
24-02-2026 11:39 PM
Very odd way of doing things..
13-04-2026 11:15 AM
Hi Linzi,
As of today 13 April 26 can you confirm what is the latest version pretty please?
13-04-2026 02:39 PM
Hi @KaBoom786
Thanks for coming here.
@JimM11 has provided information in the thread to help with the firmware.
20-05-2026 04:33 AM
Can you send me a direct download link as my router has been hacked...
20-05-2026 07:27 AM - edited 20-05-2026 07:52 AM
@rmajkla : There is no repository of router f/ware from which they may be d/loaded. EE will auto update your f/ware in its own time, usually overnight. What version is showing currently?
How & why do you think your router has been hacked? It would be most unusual, if not impossible.
12-07-2026 12:10 AM
I have had EE’s 1.6Gb package with the Smart Hub Pro 7 for around two weeks. I upgraded from the 1Gb package, although I had to leave and rejoin as a new customer because there was no direct upgrade path to the 1.6Gb service.
When the service was first activated, the hub was running firmware version r3.8.25-R-1595997-PROD-1. Wi-Fi 7 devices using the 6GHz band would either fail to connect completely or connect only intermittently.
After two days, the hub updated to r3.8.26-R-1595999-PROD-1, after which I lost all 6GHz wireless connectivity. The only workaround was to disable the 6GHz band, forcing my Wi-Fi 7 devices to connect using either 2.4GHz or 5GHz.
The wired performance has been excellent. When connected by Ethernet, I consistently receive speeds of around 1.5–1.6Gbps, so I have no complaints about the broadband connection itself.
I contacted EE and spoke to a technical support representative who was part of the team dealing specifically with 1.6Gb service issues. He advised that a newer firmware version, beginning with R4, was available and said he could not understand why my hub had not received it.
I asked whether the firmware could be pushed manually using the hub’s MAC address. He explained that this was not standard practice, but I mentioned that EE had done something similar for me several years ago when I had an issue with the Smart Hub 6. He said he would ask his team leader whether it was possible.
However, when I asked whether I might need to request a manual update every time new firmware was released, he said that this was possible. The eventual solution was therefore to send me a replacement hub.
The replacement arrived yesterday and is running the original r3.8.25-R-1595997-PROD-1 firmware. It has not yet updated, and its behaviour is exactly the same as the previous hub when it was running that version.
I am therefore not particularly optimistic, as I do not believe there was anything physically wrong with the original hub. This appears to be a firmware issue. When the wireless connection works, I can achieve speeds of around 1.4–1.6Gbps, but the connection is too random and unreliable to be usable.
The technical support representative is due to contact me on Tuesday, 21 June, to follow up.
Has anyone else experienced this issue, or does this situation sound familiar?
