Incorrect WIFI Password On Smart Hub Plus
mirrors90
Skilled Contributor
Skilled Contributor
Hi Team!
I'm now set up on the new EE, Smart Hub Plus set up yesterday - but I've got an intermittent fault with it - it keeps kicking me off wifi saying "INCORRECT PASSWORD" - has anyone else had this error and if so how did they get it fixed? it's very random and frustrating. It is 100% the correct wifi - it just kicks people off.
Ethernet is fine - solid as a rock - but the wifi is incredibly flakey!
mirrors90
Skilled Contributor
Skilled Contributor
FYI, this is the smart wifi extender which causes it. One of them goes rogue and all those connected to it get booted off.
The only way to fix it is to reboot the extender.
12 REPLIES 12
James_B
EE Community Manager
Hi @mirrors90,
Is this only happening with one particular device?
mirrors90
Skilled Contributor
Skilled Contributor
morning James , no it’s happening with several devices at once. It’s happened throughout the last 24hrs - very randomly!
James_B
Hi @mirrors90,
Please try forgetting the network on the affected devices and reconnecting.
mirrors90
Skilled Contributor
Skilled Contributor
Already done that, still no avail.
I’ve turned it on and off as well - device and router .
James_B
Please can you share a screen shot of the error message you see when a device disconnects @mirrors90?
mirrors90
Skilled Contributor
Skilled Contributor
HI James ! Sorry I had a call from EE as I logged this - they reset the hub remotely to factory settings - now we’re using the default WiFi password and they’re sending an engineer - they said that it could be the amount of devices connected - which weirdly the bt smart hub 2 didn’t have any issue with.
will let you know if it occurs again - but so far we’ve not been kicked off again in the last hour
James_B
Thanks for the update @mirrors90 🙂
@mirrors90 - out of interest, do you have a Smart WiFi extender on the network as well as the Hub?
mirrors90
Skilled Contributor
Skilled Contributor
Hey Bob
yes, smart WiFi plus - but it keeps “dropping off the network” according to the app. I did some digging with EE and was advised that the app is faulty and do not pay attention to it whilst the devs work on it - it is on the network but the app likes to show things which are not strictly true.
I mean, it’s fine - it works, but there’s definitely some beta testing going on here!
not had any kick offs on the WiFi since ee factory reset my hub and we’ve been using the factory settings in 28 hours.
