16-08-2024 11:02 PM
Hi everyone,
Has anyone ever ran into an issue where "can't find a static IP address" or "can't connect to DHCP server" stops you from connecting to the internet via an Ethernet connection? My Xbox Series S and my ASUS tower desktop are both having the same issue. Wondering whether its something to do with the router, or perhaps my ethernet cable.
Thanks you,
CJ
16-08-2024 11:08 PM
Which router? What EE BB plan are you on?
16-08-2024 11:31 PM
It's the Smart Router. I'm not sure about the plan as my father set it up.
17-08-2024 01:25 AM
When this happens next run the command ipconfig /all on the PC. Obscure any personal info.
