I keep getting lag spikes like every 20 seconds while playing Fortnite
Shakeel_
Hello,
I get lag spikes like every, let's say 20 seconds, while playing Fortnite, and it's not good, as it ruins the fun for me. My internet is fine, I have the 73mbps plan, and get approximately 54mbps. I even tried changing to Wi-Fi 6 compatibility and Wi-Fi 5 as well, I think it did help a bit,  but I'm not sure, I kept it on Wi-Fi 6 compatibility.
I've had so many technical problems when moving into my new home, a good afternoon with friends playing Fortnite is so good, so I would LOVE a fix. 😅
23 REPLIES 23
Shakeel_
C:\Users\PC>ping 192.168.1.254 -n 300
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Reply from 192.168.1.254: bytes=32 time=5ms TTL=64
Reply from 192.168.1.254: bytes=32 time=26ms TTL=64
Reply from 192.168.1.254: bytes=32 time=150ms TTL=64
Reply from 192.168.1.254: bytes=32 time=4ms TTL=64
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Reply from 192.168.1.254: bytes=32 time=3ms TTL=64
Reply from 192.168.1.254: bytes=32 time=6ms TTL=64
Reply from 192.168.1.254: bytes=32 time=107ms TTL=64
Reply from 192.168.1.254: bytes=32 time=12ms TTL=64
Reply from 192.168.1.254: bytes=32 time=7ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1262ms TTL=64
Reply from 192.168.1.254: bytes=32 time=529ms TTL=64
Reply from 192.168.1.254: bytes=32 time=213ms TTL=64
Reply from 192.168.1.254: bytes=32 time=203ms TTL=64
Reply from 192.168.1.254: bytes=32 time=319ms TTL=64
Reply from 192.168.1.254: bytes=32 time=10ms TTL=64
Reply from 192.168.1.254: bytes=32 time=8ms TTL=64
Reply from 192.168.1.254: bytes=32 time=11ms TTL=64
Reply from 192.168.1.254: bytes=32 time=211ms TTL=64
Reply from 192.168.1.254: bytes=32 time=15ms TTL=64
Reply from 192.168.1.254: bytes=32 time=18ms TTL=64
Reply from 192.168.1.254: bytes=32 time=20ms TTL=64
Reply from 192.168.1.254: bytes=32 time=61ms TTL=64
Reply from 192.168.1.254: bytes=32 time=16ms TTL=64
Reply from 192.168.1.254: bytes=32 time=13ms TTL=64
Reply from 192.168.1.254: bytes=32 time=19ms TTL=64
Reply from 192.168.1.254: bytes=32 time=165ms TTL=64
Reply from 192.168.1.254: bytes=32 time=35ms TTL=64
Reply from 192.168.1.254: bytes=32 time=528ms TTL=64
Reply from 192.168.1.254: bytes=32 time=167ms TTL=64
Reply from 192.168.1.254: bytes=32 time=367ms TTL=64
Reply from 192.168.1.254: bytes=32 time=553ms TTL=64
Reply from 192.168.1.254: bytes=32 time=368ms TTL=64
Reply from 192.168.1.254: bytes=32 time=372ms TTL=64
Reply from 192.168.1.254: bytes=32 time=326ms TTL=64
Ping statistics for 192.168.1.254:
Packets: Sent = 300, Received = 300, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 1262ms, Average = 22ms
@Shakeel_ ? All wireless from your PC to the EE router, it's random, no pattern to it, so you either have a wireless issue, or if only your pc was connected, then possibly issue on it. Can you not get a length of Ethernet cable to join them up and test?
I have ethernet but it's connected to my extender. I'll try to do a test with Ethernet straight to the router.
Shakeel_
Everybody, I fixed it, I just used my old router (Linksys Velop), this is a 3 IN ONE for me, firstly, since I'm a gamer, I can get more speed with this router since nobody else is on this router, secondly, I think I am getting more speed on this than I was on my old one, FINALLY, NO MORE LAG SPIKES!
Thanks to @JimM11 for trying to help, and thanks to GrumpyMan's REVIEWS for making this video, https://www.youtube.com/watch?v=5tuZ72tYMYM&t=181s
I hope everybody that's had the same problem found this helpful, please let me know! 😁
By the way, I couldn't open the web interface, so try installing the app.
