I have EE broadband and a BT landline. Will it work ok after voip comes in?
Yatoto
19 REPLIES 19
Community Hero
Community Hero
@Yatoto Voip has been around for well over 20 years, is your BT / EE landline currently digital or not and does your current equipment that you have and or using at present have an ATA port on the back of it!
My landline is not digital at the moment, and I haven't got an ATA port on my EE router.
Community Hero
Community Hero
@Yatoto Then the EE Hub will need to be replaced at the point the Line gets switched over to a digital service, see the current EE one's below.
OK. Thank you.
I have the same, landline from BT & BB from EE, except my BB is Full Fibre & yours isn't.
In Dec my BT analogue landline was switched to Digital Voice w/out any home visit, use of router or any other new kit in home. It still uses my existing home phone sockets & internal wiring w/out any change. All the work was done at the exchange. All I had to do was change any short (7-digit) local nos. in my phones' phonebook to include the local area code. There is no cost associated with the switch & line rental & call plan are unchanged. See Digital Voice with No Router, No Change or Extra Kit in Home, No Engineer Visit
This new system which I call "DV from the exchange" is called variously Dedicated Landline Service or Home Phone Standard or SOTAP(Single Order Transitional Access Product). It it aimed at users with a landline who do not have BB. It could well be a stop-gap until Jan 2027 when they shut down analogue lines.
But then you'll need to move your landline from BT to EE.
Yatoto
I have got a fairly recent EE Smart Router so I just need to transfer my landline to EE then.
The white EE Smart Router doesn't support DV. It has no phone socket at back.
Community Hero
Community Hero
@Yatoto Are you like @XRaySpeX was, had two separate lines into your home? In your case one on the BT phone line and the other used for the Broadband Internet connection?
