How do I switch from bt to EE
Bhpheba
I need advise on switching from BT ro Ee
Maestro
Maestro
@Bhpheba If you are doing it all online, do so through your MyBT account, if you are doing it over the phone, try to get to the BT support CS side, and have them arrange your transfer from BT to EE. Will also post the help guide link below may help with the migration and there is a video also not sure if it's any good, but everything helps. Hope it all goes smooth for you!
Moving from BT to EE Broadband – First Bill Explained | Billing Help | EE
This 2nd link may help with the BT EE coming together, just look for the FAQ on the screen page.
BT and EE are coming together to give you more | Learn more about the relationship between EE and BT
Do it thro' BT & you won't need to pay exit fees.
Maestro
Maestro
I wouldn't do that man, I did and my connection got tanked day one and hasn't gotten better after a router swap or a WIFI booster
