Home broadband. Who you gonna call - BT or EE
Mescubasteve
My home broadband is less than 1Mbps. Should be 30! Who do I call - and how?
Your contract is with your ISP. If you're with EE you call EE. If you're with BT you call BT.
For EE: Try calling CS on the Freephone no. (Opt 3) in my sig.
