GPO Connection Box
debbieturner966
Hi, I have transferred to the EE/BT Digital landline but still have an old GPO Connection Box, could somebody please advise if this is still required or can I have it removed.
Thank you
It is not required & could be removed. With a Digital landline the digital phone is either plugged into the router or into a supplied adapter if the phone is required away from the router.
10 REPLIES 10
Thank you, much appreciated
Storm500
Expert Contributor
Expert Contributor
@debbieturner966  Do you have:
  1. FTTP (full fibre) with ONT fixed to your internal wall?
  2. Openreach master socket, which could be connected to the old GPO box?
Hi, not really sure but have a open reach white box that has the router and the phone cable is feed into that
Storm500
Expert Contributor
Expert Contributor
Can you please post a photo of the Openreach white box?
Once Full Fibre & its ONT is installed you can get rid of that BT socket as well as the GPO connector box.
Storm500
Expert Contributor
Expert Contributor
Thanks. You have FTTP, fibre to the property. The old copper is now redundant, but it may still have 50v across the pair. If you can find where the cable comes into the house, which may be the GPO connection box, you can remove the cable and boxes after it within the house.
