Fttp max speed guarantee is worthless
Cardiffjamesh
Ok so our town hav fttp installed late last year 2022 signed up jan 23 for the 900 package but struggling to reach 300 407 is the max iv ever had open reach been out twice nothing wrong with line to house it’s a issue with exchange just got off phone with ee thay want to downgrade my package to 500 for the same price lol I asked them about the guarantee and it don’t apply to me as iv been offerd a downgrade **bleep** for same price and I would loose my Xbox pass any one know about the guarantee
11 REPLIES 11
pip11
Scholarly Contributor
If you are expecting 900mb on a wireless connection you will be sorely disappointed. Most wireless devices currently popular can't support it.
What device are you using to test and how is it connected? An Xbox, depends on which one you have. The Xbox series X/S can do about 850 but that will be a wired connection.
If you would like help with your BB speed or connection issues, please would you carry out the following steps for starters, which will enable us to diagnose the problem and advise you further.
1. What are all EE's estimated speeds which you'll find in your MyEE for BB under Your broadband speed?
Cardiffjamesh
It’s a ee own test from inside there diagnostics there getting 300-400 slowest was 280 I think thay got last week that picture is from a Ofcom Sam knows testing router hard wired with cat6
Cardiffjamesh
 the 400 is on cat 6 and ee get the same on there tests
Cardiffjamesh
This is also running The SamKnows Whitebox is a dedicated device for measuring your internet performance.
It’s ideal for IT professionals, advocates of better internet and users who want assurance about their internet service.
The latest version, Whitebox 8.0, is capable of measuring fixed-line broadband connections of up to 1Gbps.
The Whitebox measures a wide range of network and application-specific properties, including download speed, upload speed, video streaming, online gaming stability, latency, and packet loss, to name just a few.
The Whitebox does not directly improve your internet. It provides you with the data to help you improve your internet performance.
The Whitebox is...
  • capable of highly accurate internet performance tests available.
  • a trusted measurement unit that you can use to track your home internet performance, so you can be confident that you are getting the service you expect.
  • part of SamKnows’ specially developed Test Kit, which is used by internet service providers and government regulators, and includes ConnectedHome and the SamKnows mobile app.
The Whitebox is NOT...
  • a way to improve your internet speed or performance by itself.
  • a replacement for your router and/or modem.
  • a replacement for any other Wi-Fi access points in your home.
  • a smart meter for energy and gas usage.
Technology and metrics
The Whitebox stays in one place and only runs regular tests when you are not using the internet. This reduces the window for variables and other external factors that can influence the metrics. Thanks to this diligent testing method, the Whitebox will give you more consistent data about your home broadband performance over time.
All metrics and data gathered by your Whitebox can be viewed on your ConnectedHome dashboard.
To find out more about how to interpret the data your Whitebox gathers, have a look at the Understanding your data section.
You can read more about the technology inside the Whitebox, and projects it is being used for, on the SamKnows Megablog.
The current generation of Whitebox (8.0) is capable of measuring 1Gbps downstream and upstream over both TCP and UDP.
Product name: SamKnows Whitebox
Model: SK-WB8
Networking: Dual 2.4 GHz and 5GHz Wi-Fi radios, supporting 802.11a/b/g/n/ac
Main processor: Dual-core 880MHz CPU
Memory: 128MB RAM
Storage size: 16MB flash storage (not accessible to users)
External dimensions: 16.4 x 11.2 x 2.6 cm (width x length x height)
Weight: 216g
Input / Output: 1Gbps LAN interfaces x 4, 1Gbps WAN interfaces x 1, USB 2.0 port x 1 (non-operational)
Power: AC 12V at 2000mA, 50/60Hz
@Cardiffjamesh   I’m sorry but do you have an internet speed issue or are you trying to sell something ?      That last comment is a copy and paste.
Cardiffjamesh
Yea if you can see the above posts iv got under guaranteed speeds I don’t know where u getting the selling idea from if it’s from that copy and paste it’s from the government Ofcom site just saying the router that thay are using in my house to monitor ee speeds
Cardiffjamesh
Yes, I know it well. The URL would've been sufficient rather than a cut & paste job that does not have much bearing on the issue.
