02-01-2026 03:00 PM
As I was saying tried all the usual fixes. Can’t find how to talk an engineer
can see any way to register a fault
Any help or advice?
thanks
02-01-2026 03:17 PM
@stuartburge456 What model of router do you have?
02-01-2026 03:25 PM
Which model extender is it? There's no flashing Green listed in Fix a problem with EE WiFi Extender . Have you tried moving it around?
Try resetting it up by pairing it to the router nearby & them moving it to where you want it.
02-01-2026 03:50 PM
Hi XRaySpecX
Tried moving around not change. I understand it's an extender 6. I also understand about the flashing green light is not referenced.
It starts flashing immediately on power up - I don't get any other colours no matter what I do- my last option is to throw it out the window.
I can't get it to pair to the hub - it's stubborn and only knows a flashing green light. When it was set up, it worked fine. It smells like an early latent failure.
Do you know if you can you pair by using a lan cable between the hub and extender to reset it.
02-01-2026 03:52 PM
Hi Ewan15
its the smart hub plus. It’s working fine. I even powered it down to see it was interfering with the extender - still get a flashing green light.
02-01-2026 04:15 PM - edited 02-01-2026 04:47 PM
Yes, pair it to the router by Ethernet, wait about an hour & then move it to where you want it.
02-01-2026 04:36 PM
I will give it try - to see I can them to see each other.
Thanks again
