WifI Extender with Home Hub 7 Pro
Memnon
Background having Wifi range issue - was find for 18 months then issues, EE Home Tech advised there are known problems with HH 6, and suggested I upgrade to HH 7 Pro  and WiFi Extender Pro .. as contract was up, I did so at less than the cost of the previous contract.
Put in Hub, paired the Extender then went and put it in same place as previous extender - won't connect (stays flashing Orange)
EE sent another Hub & Extender - no difference.
Spent Hrs on call with support - resetting hub, resetting extender - no change.  At end of each failure, I would plug in HH6 and its extender and it would connect straight away.
Today a guy on support (Josh) who seemed to know his stuff ....took a different approach; he decided to install a 'Bridge' or daisy chain connection.
Basically, h/w rest of extender then pair first using Ethernet, then disconnected, then added second Extender - paired and left it connected by Ethernet.
Then put the first one in the required location - and it connected fine.
He said that the Bridge connection allows Extender to Extender connection without using WiFi, it uses its own RF connection.
It works - wonder if anybody can explain any details behind this set up ?
Are HH 6 & HH 7 Pro BT routers? Or is just the former BT's & the latter EE's Smart Hub 7 Pro?
Maestro
Maestro
@Memnon Yes, the EE does not have the tools to set it all up and work in a simple method!
Memnon
Old one was EE SH32B
Extender was EE SW30A
Then by replacing 'HH' by 'SH' in OP you'll almost be there.
