15-06-2026 11:18 AM - edited 19-06-2026 10:06 AM
Following a recent firmware update, some Smart Hub Plus customers may find that certain WiFi devices or WiFi extenders have trouble connecting.
Our engineers have identified the cause of the problem and are now rolling out a fix to affected Smart Hubs.
If your wireless devices aren't connecting and you have a Smart Hub Plus, setting the 2.4 GHz channel can resolve the issue.
If you have devices that will not connect, please try reconnecting using Compatible WiFi.
We are working as fast as possible to fix this issue, but in the meantime, some of our customers have found the following steps help:
You can find all the latest updates on this issue in Fix problems connecting devices to your Smart Hub Plus or Smart Hub 3's WiFi | Broadband Help | EE
09-07-2026 09:59 AM
Thanks so much for your response - it is the mini tv box that was replaced. I just checked and it is a Smart Hub SH31B - not sure what model this relates to? Thank you again, Denise
09-07-2026 10:11 AM
@DottyR : That's the Smart Hub 6+, suitable for ADSL, partial Fibre & Full Fibre connections.
09-07-2026 10:21 AM - edited 09-07-2026 10:32 AM
@DottyR By now your EE Smart Hub 6+ should have been updated FW wise, the version that EE was doing is linked below and if you are an EE App user, think it shows you on that. For the TV side nothing is mentioned regarding your error so that needs to be addressed by EE CS someway.
FW: r4.26.3-R-1923144-PROD-83002 and the gui is at App version 3.14.5 12/06/2026 OP Posted
Search linked below if needed not a EE TV person.
From what i can see that error is years and years old so you need the help off EE CS as there seems to be many ways to look at it starting with the account side onwards, good luck with it all!
09-07-2026 02:34 PM
Well, that's a shame...
r4.26.3-R-1923144-PROD-83002 was installed on 16th June on my SH31B (aka SH32?)
It instantly cured my wi-fi connectivity issues.
And I thought that it had also cured my 'Device Re-Naming' issues.
But at some point in the last three days, ALL of my Customised Device Names have reset / been reset to default.
The Hub hasn't been powered-down, as the Technical Event Log is still starting from 16/06/2026, 02:37:49.
So - it looks as if the latest Firmware is still not 100% Bug-Free....
09-07-2026 02:40 PM
@Gelert5 Shock Horror is the App correct, the Hub not or both all wrong, wonder if it's an App update change, you know how they like to change that every two weeks or so?
09-07-2026 05:11 PM
Judging from my one laptop that keeps re-authenticating every 6 seconds, on r4.26.3, no, this update has not fixed every problem that r4.26.1 intoduced!
10-07-2026 03:31 PM - edited 10-07-2026 03:51 PM
@JimM11 App is correct, and Hub is incorrect.
Interestingly, the App was updated yesterday - so you might have narrowed-down another bug in the flakey Firmware.
I'll rename all of my devices now, and I'll turn-off auto-update for the EE App via the Google Playstore settings.
That way, I'll have to manually allow the EE App to update - so I can check just before and then afterwards whether / if / when the Hub is affected (again?)
Remind me - How much are we being paid to Beta-test all of this EE stuff...? 🤣 🤣
*EDIT* The latest version of the App is SO SLOW and LAGGY....
It's going to take me an age to rename my Devices - deep fudgy joy, not...! 🙄
10-07-2026 06:19 PM
@Gelert5 Heh, if it did not keep doing it then you would have nothing to keep you on your toes, Broadband wise....
There's just not enough money in the world to be paid for Beta testing, to much wrong and not enough fixing going on. They must have seen your reply for the speed you could knock it all back into shape again...😶🙄
15-07-2026 04:10 PM
Just went to upload and save my Technical Event Log today (15th July), and came across this new load of old malarkey....
This 'malarkey' definitely wasn't displaying yesterday (14th July) at 1315hrs when I uploaded my Technical Event Log then.
1) This is the 'Home Page', showing 'All Wireless Disabled'. But, quite clearly, this is NOT TRUE!
All Wireless IS enabled, and 'My Network' proves this by showing 9x Wireless plus 9x Ethernet Devices connected:All Wireless Disabled #1
2) This is the 'Advanced Settings' page:All Wireless Disabled #2
3) This is a more detailed look at my 9x Ethernet Connections, and my 9x Wireless Connections:
4) This is what I get when opening the 'Big Red Wireless Box' from the Advanced Settings page. I certainly haven't / didn't select 'Disable all wireless' - and yet there it is, er 'Disabled'...
5) When I slide the 'Disable all wireless' switch to 'No', all of a sudden my Network name, Security type, and Security password fields are completely empty.All Wireless Disabled #5
Which is all very weird, as all of my Wired AND Wireless Devices are still connected.
And the Wireless devices are connected to my customised Network Name (aka my SSID), using my Security password.
No, the Hub has not been updated and/or powered down since 16th June, as the Technical Event Logs show.
No, the 'App' has not been updated for a few days.
No, I'm not going to Power-Cycle the SH31B (32), or re-enter my SSID credentials - unless I absolutely have to e.g. the entire system locks-up. I'd like to see if this phenomena disappears as quickly / mysteriously as it appeared - and / or if it's going to get worse....
Sadly, yet more flakery bubbles to the surface, regarding this latest Firmware. 🙄
15-07-2026 05:57 PM - edited 15-07-2026 06:22 PM
@Gelert5 DO NOT RULE out the App having a play with it all, and little strange the 3rd picture showing all your Ethernet connections does not tally with the first two totals as well, EE definitely keeping you on the toes with it all! wonder why the 6Ghz is also showing on a SH31B hub? is that an addition now or have you noticed since the upgrade to the FW....
Until the save is applied, and the warning possible explaining network may be dropped for settings to be applied who knows what is going on or going to happen point in time....
Also shows all off your wireless wifi devices are on the Extender only, is that a true correct way nothing on the EE 6+ wireless wifi for the Hub?
Nope the SH31B is still a two band only unless they are pulling your chain...
@James_B You may won't to take a look see at this!
Now has the GUI look and feel off a wifi 7 Pro puppy...
