Firmware update EE smart hub plus
MarkJ67
I read a couple of posts on here saying the EE smart hub plus has received a firmware update. However, my hub is still on the same firmware version. Does anyone know what the firmware update changes are and when we can expect this?
19 REPLIES 19
My latest & it was only updated a coupla days ago:
App version:     1.13.1
Firmware version:
but I hear that some in the field have got r2.68.11-R-1260390-PROD-83002
When did you get your hub? I’ve had that firmware for a couple of months or so. Apparently there’s a new one
Actually I’ve had that firmware version since August. I’m not sure why you’ve only got it in the past couple days.
Got SH+ on 30th Dec. & it updated to above a few days later.
I believe most of us are still on
Maybe but the comment are saw used the name SH31b in brackets too
Yes, there are 3 reports on here of the r2.68.11... FW on the SH+ (SH31B).
Brilliant Contributor
@MarkJ67 It's one of those it will happen if/when it happens, and as XRaySpeX say's never sure if there is the potential mix up on the described EE Router, but common sense would be to align the features of the 2 latest Routers Pro and + so all you can do is wait and see, fixes are abundant for the + router as it has just so many oops quirk's and for sure it has NOT happened to my EE Smarthub+ as yet, so still on the
Firmware version: r1.35.0-R-1138091-PROD-83002 and this is a direct copy from the status page....
@JimM11 : Abundant? It took about 3 months (May - Aug '24) to get to the r1.35.0-R-1138091-PROD-83002 update on the SH+ in a life of about 13 months (Nov '23 - Dec '24). Before then they were thick & fast. In the 4 months since Aug the 1st sighting of r2.68.11-R-1260390-PROD-83002 was 3 weeks ago,
