Fibre upgraded package speeds the same
mjjw88
Hello,
I upgraded my broadband package from Fibre 100 to Fibre 500.
I am not seeing any download speed differences. I am still only getting around 150 download, my upload has increased as expected though.
I have read online others with this issue an engineer had to adjust some settings possibly to allow the new speeds to reach my end?
I phoned support and they have checked my speeds, confirmed they are sending me 500 download to my end but its not showing on my side still same download speeds as before the upgrade.
Any help is appreciated.
9 REPLIES 9
How are you measuring speed? Have tried the speedtest in the EE app?
Hello,
I have tested speeds using multiple speed tests online e.g. https://www.speedtest.net/
Wired or wireless? Try the EE app.
I have tried both wired and wireless same results.
my EE app does not have a speed test option.
I just tried thinkbroadband speedtest wired in, speed test still the same. 150 down 70 up.
What EE router & WiFi extenders do you have (read label or post a pix)?
Thanks for your help.
I have BT Home Hub 2.
No wifi extenders, im wired in only wifi for mobiles
Post your full router stats:
  • As I'm with EE I'm not sure of the details of the BT SH2, but login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
Matt_124
Try texting HELP to 66033 so the automated system can check your line, it may then give you the option to text GUIDE to have someone give you a call back.
It's possible the speed profile wasn't fully updated when the order activated, this is something they'll be able to check for you.
Timbo45
Skilled Contributor
Skilled Contributor
@mjjw88
You might want to check/replace the ethernet cable coming from the ONT to the router. Could be a limiting factor if it's faulty or an old Cat 5 cable.
