01-05-2023 11:42 AM
Hello, I am currently on Fibre Plus Broadband and upgrading to Fibre max 100. Will I be getting a new router? I am currently not using the EE router but a TP-Link router. If I will be keeping the existing router, will I need to change the router back to the EE router before the install date?
01-05-2023 11:46 AM - edited 01-05-2023 11:50 AM
Yes, you should receive the white EE Smart Router instead of your existing black EE Smart Hub. You may not be able to continue using your TP-Link router if it doesn't incorporate a G.Fast modem.
01-05-2023 11:52 AM
Thanks, I am not worried about carrying on with the TP-Link, as it is a VR2800 so quite old. Thanks for your reply.
