EE smart hub plus wifi enhancer
TROOTERDIV
Looking for a recommendation to extend my wifi signal i have a EE smart hub plus Looking to see what's compatible with EE SMART HUB PLUS.
14 REPLIES 14
Brilliant Contributor
@TROOTERDIV That will be the EE smart wireless plus to match!
Matt_124
The official supported solution is the "Smart WiFi" service from EE: https://ee.co.uk/broadband/wifi-products
You may order Smart WiFi Plus as an additional service (£7 pm I believe) - see EE Smart WiFi and Smart WiFi Plus T&Cs
 Smart WiFi is also available as an additional service to consumer customers who purchase the Smart WiFi or Smart WiFi Plus add on.
So its another £7 per month for a smart wifi .
@TROOTERDIV If it is not included in the package that you have with EE then the addon is the price less anything you can negotiate as a discount. And that does included up to 3 devices!
Yes, it's £7 pm as I've just checked:Capture.PNG
Is there any other option can't really afford £84 a year extra on top of my broadband bill 😪 is there and other I can use .
Buy your own Mesh?
Don't really know about this stuff 🙈 only little bit like wife Extenders or booster will they work
