on 21-05-2025 11:50 AM
We are moving properties and where the front room will be has no TV ariel or Internet cable for the EE box (these are currently into a separate room).
Will EE adjust where the cable enters the property in order for a simple white cable from the receiver into the TV box?
on 21-05-2025 01:00 PM
@Marty444 Internal wiring is your responsibility, and an option could be to get someone to run an ethernet cable for you.
Or you could ask EE to change the position of the Master Socket/ONT however if it can be done you would be charged - last time I looked it was £150 plus VAT.
Or you could use powerline adapters between the router and a point near the TV.
It would be worth having a chat with any friends who have some more ideas.
