EE smart hub plus or tp link ax12
Ptc1
Hi, my 2 yr BT broadband fibre 900 package (no landline) is ending and through calling BT I've renewed to an EE 900 package (again no landline needed). A smart hub plus is being sent. I currently use a tp link ax12 wireless router as I wanted WiFi 6 and split 2 and 5 frequency that BT router couldn't do. Can I use the ax12 router with EE or is their hub plus router WiFi 6 stable, I've read that the 2 and 5 frequency can't be split but also read they can with latest firmware. Can you split them with separate ssid's?
Many thanks
Mustrum
@Ptc1   you cannot split the frequency bands, but the you can have a main and compatable SSID.
The good news is that you will not have to make any adjustments to your own router, the settings are the same for BT and EE.
Mustrum
Thank you
