EE fibre 1.6gb connection and speed issues
j33tco
So, moved to EE from Virgin 1gb package , after 24 months they were just asking too much on cost and I got a deal through EE.
Never had an issue with Virgin, speeds were always stable via ethernet and wifi, no jitter or intermittent losses, and with the odd router reboot was really good.
Iv been on EEs 1.6gb busy home bundle with the latest router and extender (wifi7)
Since install, Iv notice on multiple devices, wired and wireless, that there is latency and jitter (lag) when using websites, gaming and social media apps. And from scouring the internet, i'm not the only one.
Unable to change the DNS on this router which is crazy. Iv disabled IPV6 after some research, change firewall settings ect, and nothing I seem to do will help the issue. Speed is also getting throttled from 6pm to 12pm, tests running from 1.4gb over wireless, down to 100-150 during these times.
Iv split SSIDS so my older devices and cameras can stick toa 2.4ghz signal, and other devices using 5ghz (wifi 6 and 7 depending on the device) and all devices are experiencing the same thing.
Does anyone know any fixes or can advise where to go forward with this now. Not been a good experience so far, and also , WTH is up with this EE app, seems it decides when it wants to work or not depending on which way the wind is blowing.
Product code:
SH4-1
Serial number:
Firmware version:
r2.64.7-R-1303938-PROD-1
Firmware updated:
N/A
GUI version:
2.34.2
WAN:
PPP Connected
Data sent / received:
1.66 GB Uploaded / 39.4 GB Downloaded
Broadband username:
Firewall:
On
Main WiFi
Network name:
2.4 GHz wireless channel:
Smart (Channel 6)
2.4 GHz wireless security:
WPA3-Personal-Transition
5 GHz wireless channel:
Smart (Channel 100)
5 GHz wireless security:
6 GHz wireless channel:
Channel 69
6 GHz wireless security:
WPA3-Personal
Compatible WiFi
Network name:
Smart (Channel 6)
WPA-WPA2-Personal
Smart (Channel 100)
WPA-WPA2-Personal
[Mod edit: Please do not post personal information on the public board. Thanks!]
16 REPLIES 16
j33tco
Yes so couldn't get it to pair, my concern is the agent asked me to place the extender in the same room as the router which kind of defeats the object, after a moan this morning at 7.30am with the same issues, iv come back from work tonight with a magical FW update thats been applied, iv changed the DNS to cloudfare at the moment and will share any improvements here when iv had some time to play with it all.
@j33tco That's the point that the agent was try to get across, leaving the two units together and actual using the connect by network method for pairing the two devices is what works best, but at least your system has now FW updated, and the EE Router and the Smart wireless should be a matching set, when you do move the smart wireless to it's position leave it a couple day's to settle in place and train the mesh learning that it will be doing!
Have a feeling that you may not like all the little foibles that are required with the unit's its all a work in progress even though they are now a year old!
j33tco
Right , so Iv bought a new laptop, top of the range, getting disconnects whilst gaming, looking through the settings, its the only device thats connected to the wifi extender, Im sat literally 4ft away from the hub and the extender is in another room upstairs lol, is there anyway of forcing a device to bypass the extender and connect only directly to the hub ?
@j33tco Yes, switch the Extender off!
Peter_W
Hey there @j33tco!
Could you possibly have been closer to the extender when first connecting to your network, and therefore the laptop has become thinking this is the main access point?
If you haven't already, I'd recommend totally forgetting the network in your laptop's settings, then set up the connection again, making sure you're right by the main Hub.
Peter
j33tco
Everything seems to be ok at present, still seeing some weird fluctuations in speed after 6pm every evening, but a quick Wi-Fi off and back on again on the device seems to fix, will keep monitoring. For now, Iv turned off the extender, its not needed. Speedtest over Wifi 7 on a new device.
Wi-fi calling is still super bad though, not sure what I can do about that though.
@j33tco Who is your mobile provider, wi-fi calling did work perfectly well on the EE Smarthub+ Router with an EE connected mobile, as sugar 4G signal but perfect and great signal indoor/outdoor so the EE web site reported for the area, duh!
Was simple no wi-fi calling, no mobile as non existent 4G...
