09-06-2026 01:08 PM - edited 09-06-2026 01:12 PM
Just had this text from EE:
"Hi, it's EE.
12-06-2026 12:08 PM
PS I don't have an extender mainly because there shouldn't be the need for one & more extra expense.
12-06-2026 12:09 PM - edited 12-06-2026 12:12 PM
@addedomaros Updates are pushed when EE does it no other time? That may also be true as you have posted.
""PS I don't have an extender mainly because there shouldn't be the need for one & more extra expense.""
12-06-2026 12:33 PM
Hi Cliff.
Yes all 3 of the fixes you refer to have been tried on multiple occasions now.
Comp Wifi is switched on and dedicated to 2.4ghz.
All the fixes work for up to a day then all of a sudden they have all gone off line again.
As mentioned before my network functioned perfectly until around 10 days ago when all this started. Numerous other devices work fine.
12-06-2026 12:37 PM
@JonT69 Is Comp also set on Fixed channel if that can be done?
12-06-2026 12:37 PM
Hi Jim,
No third part devices. Just the EE Smart Hub 6 and Extender 6.
Interestingly it just chucked my phone off so had to reconnect to wifi.
Jon
12-06-2026 12:39 PM
@JonT69 Do yourself a favour and look at it all with the web manager if possible, https://192.168.1.254 and ideally not with a mobile phone.
14-06-2026 07:05 PM
Anyone had the new firmware yet? Not here. Perhaps they're doing a staged/beta rollout to see if it introduces any new issues. Be nice if they told us,
14-06-2026 07:16 PM - edited 14-06-2026 07:44 PM
@Cliff_G From other post. Same OP posted confirmed the gui as no change...
Edit:- confirmed version now below..... Working well no drops, but OP has left it on the fixed channel currently.
FW: r4.26.1-R-1860948-PROD-83002 and the gui is at App version 3.14.5 25/05/2026 OP Posted Stability Problem
FW: r4.26.3-R-1923144-PROD-83002 and the gui is at App version 3.14.5 12/06/2026 OP Posted
14-06-2026 08:08 PM
Fingers crossed. Will update my end over the next 24 hours to see whether it has worked.
Credit to them for getting on with it.
14-06-2026 08:16 PM
@JonT69 You just have to keep the eye out for it, only one OP has posted so far that the Updated has been applied to his hub!
