EE WiFi 7 Pro Ethernet Backhaul
wizzywig27
Skilled Contributor
Skilled Contributor
Hello
Does anyone know how to set up ethernet backhaul with the smart WiFi pro?
33 REPLIES 33
Well i turned everything off and re started.
It now shows connected via ethernet
OK.
If I wanted to change to a wifi 7 mesh alternative that supports backhaul and is reliable.can you let me know the kut with some links please
wenklaw
Decos are pretty good and easy to set up, I ran one for a while and it worked extremely well via a wired backhaul.  UniFi stuff is good but not particularly plug and play and needs controllers and a bit of effort.
Great.
I'll see how it goes.
Can the decos still use the EE 4g smart hybrid connect?
And can I use my EE account credentials to get the decos on my 1.6gbps plan with ee
