21-11-2024 08:30 PM
Hello
Does anyone know how to set up ethernet backhaul with the smart WiFi pro?
08-04-2025 07:33 PM
You're so right Jim. Rewired lots of stuff today and the old CAT5E cable works just fine if I go direct from Hub Pro to the extender. Will not work through a switch though! So my plan is to rund CAT7 across the attic to each extender from the Hub Pro, then try a dumb switch (2.5G) I got from Amazon today. If the switch doesn't work then I'll have to plug my 3 extenders in directly to the switch ports on the Hub Pro. Which of course gives me a new issue in as much as the Hybrid Connect will take the only remaining port. This leaves no uplink for my main switch with all my kit on it. So, a switch on the Hybrid Connect will be the next challenge. I have to say, the whole exercise of moving from Virgin Media (faster, modem mode and more standards based) has been an utter nightmare. I was paying £32 a month and getting 1.8GB consistently, now I'm paying £64 a month and have nothing but hassle, no VLANs, cannot extend the guest network, no extra SSID's - become an absolute mess! I really think EE need to bite the bullet and just allow people to run their own networks. After waiting years for FTTH, i'm struggling to see any benefit whatsoever! Anyway, rant over. Just hope they loosen up on the "control" they have and deliver a viable service to their customers. But hen, I guess there would be no fiddling and excitement!?
08-04-2025 07:55 PM
@MukeMan Hybrid connect will NOT have a 2.5Gb/s port, that's for sure more than likely just a 1Gb/s, and lot slower speed on 4G, hope you read the document as to what it does when back up kicks in and what you lose operational wise.
That's why the ISP supplied router is so tied down, you would have been way better using your own with the requirements that you needed for a router.
04-07-2025 10:10 AM
I've been having similar issues with my ethernet backhaul too.
The Web interface speeds do not correlate with speeds I can achieve from the extenders.
My main problem is the extenders appear to reduce speed at random when wired in. Pull the ethernet cable out and back in again and it'll reconnect at 2.5gbps. Random amount of time later, test speeds again at the extender and we're down to 300-400mbps.
The wired backhaul is not very reliable. Overall, I'm quite disappointed with my EE Wi-Fi 7 units after 6 months of using them.
04-07-2025 10:39 AM
My backhaul shows unusual information in that I have three extenders directly connected to the hub via ethernet at 2.5G but it reports that Extender1 and Extender 2 are connected to the hub at Ethernet 1000 Mbps and Extender 3 is connected to Extender1 at Ethernet 2.5GbE. If I put a switch in between any of the extenders and the hub the switch operates at 2.5G transmission but the hub still shows 1000Mbps.
