EE Speed Test Function
ShahJitu
We are a new customer to EE.
Just wanted to check the broadband speed for our product.  Sent on a wild goose test from the Router admin screen to the App, no such function exists as of 24/6/25. This was confirmed by EEGuide Aman who was very helpful and gave me the following link to a BT existing test:
https://www.bt.com/broadband/check-your-broadband-speed
It works. I also suggested to Aman that that EE IT put up a message in the App, that the Speed Test function is under development.
Also try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Maestro
Maestro
@ShahJitu Speed test function is not under development, it was working fine, and got broke to some user's!
