EE Smart Hub Pro 7 not port forwarding correctly
mrhuk
I've set up a static IP for my PC and forward 44274 but it remains closed and I can't access it. I've never had an issue port forwarding on any other router, including the BT Smart Hub 2 which was replaced when I moved to EE Fibre 900.
I even tried enabling DMZ, but that didn't help either. If anyone knows how to fix this, please let me know. Screenshot 2026-03-17 031354.pngScreenshot 2026-03-17 031436.pngScreenshot 2026-03-17 031205.png
Maestro
Maestro
@mrhuk Have you tried changing the name> would not use the # symbol as it is a special character may be causing an issue so worth changing it to see.
bobpullen
What do you have listening on port 44274? The port will only show as open if there's a service/application actively listening for traffic.
Given it's a Windows machine, have you checked that the network connection is still set to 'Private' rather than 'Public' when connected to the Pro? Windows has a habit of sometimes reverting that setting when connecting to a 'new' network.
