EE SMART HUB PRO (SMART HUB 4)
Ryan01
Hi, I was just wondering if anyone knows when the Smart Hub Pro will release.
ive seen on some websites about the 17th of September, but is this true?
I want it if im going to upgrade to the gigabit package, as most of my devices support wifi 7 or the 6ghz band in general.
31 REPLIES 31
Ryan01
Openreach have already put the modem in that can support over gigabit speeds as at the time their was a slight shortage of the other modems, but yeah I like future proofing the network at my home all the time when I get the opportunity
Brilliant Contributor
@Ryan01 And its all going in your favour so far.👍
Ryan01
So far yes it is, another reason why I want it, it’s not so big in terms of width 😂
@Ryan01 You like the look see! only thing puts me of is the colour, prefer dark, but you can't win them all...🤣
Ryan01
Clicked the wrong button 🤦‍♂️ but I’m able to fit it on the unit easier with it not being so big width wise
Ryan01
Just got the smart hub pro today!
it’s been flawless so far on the gigabit package, the 6ghz band also helps with all the other new features included with wifi 7!
you also get a booster included with it also for only £10 a month extra! I’d say that’s a awesome deal!  
@Ryan01 Well done, looking like you are the first success!!!!👍👍
@Ryan01 Your off bands? Guest network? Looking like some flexibility on it!
Ryan01
Three bands 2.4 all the to 5ghz, theirs a compatibility wifi tab also for older wifi devices that can’t support the latest wifi standard and yes the guest network is also a thing too.
and for the guest network the smart hub pro supports nfc, but it doesn’t allow nfc for the main network itself.
@Ryan01 Thanks for the reply, good to know!
