EE Hybrid Connect
iammbuk
Skilled Contributor
Skilled Contributor
Hi
I'm looking at buying a EE 4G hub (like this one      https://ee.co.uk/broadband/pay-monthly-mobile-broadband-gallery/smart-4g-hub-details) does anyone know if I connect it to my ee WiFi 7 smart hub it will allow me to use hybrid connect and fall over to 4G in the event of an issue?
Cheers
Maestro
Maestro
@iammbuk It is not a hybrid connect unit!
Matt_124
You could call EE and ask to add their official Smart Hybrid Connect product for (I believe) £7pm.
This is the only failover connection officially supported on EE's broadband hardware.
It depends on the current plan you are on, as well as their signal estimation in your area, as to whether they'll be able to do this for you.
