EE Broadband capped when actually downloading?!?!
DarrenP89
I recently changed to EE broadband(Fibre 67 as full fibre is not in the area yet)
Before I changed I asked if it was a capped download when downloading games due to my then internet (Talk Talk) at the time capping download speeds to 4-5mb when downloading a game but speed tests always showed 70+mbps.
The man said I would get the full 67+mbps when downloading games, streaming etc and said that my previous supplier was limiting it but EE is not like that. I spent a good 5 minutes making sure he understood what I meant by a download cap with games and he confirmed what I was on about and said "You will download games a 60mbps and much quicker"
Well I guess he was a big fat liar. The speeds are worse than my previous supplier. Speed tests showing 40mbps with a direct cable plugged in, Tried upgraded cables etc and no different. However when they "Run a test" theirs shows 60+ mbps.
Is there anything I can do to get any compensation or the full speed when downloading. In a world where games are 70-100gb now I really dont want to wait 8-10 hours to download games.
Cheers in advance...
@DarrenP89  Have you ran a speed test yourself via the EE app ?  Your game download can also be hindered y the server you’re downloading from.  If that server is being hammered this will effect your download speed.
Maestro
Maestro
@DarrenP89 You may wish to have a look at the EE Router setting's in status with the web manager, it will show you what the router has synced at on your connection for the up/down speed's, whatever the value is at then you will not get anything quicker than that, speed test's are only a guidance as they push very little data through the testing, once you get on the server for trying to download then as @Chris_B has pointed out, you are dependent on what is available for it pushing out the speed to your device.
Even on a 1gb/s connection if the server is busy then speed can fall dramatically.!
When downloading a file or game its speed is usually measured in MegaBytes/sec (MBps) while BB speeds are quoted in Megabits/sec (Mbps). There's a factor of 8 between the two. Are you sure you are comparing like-for-like?
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
