on 01-05-2026 02:03 PM
Stay with me:
Switched from Virgin to EE. EE came out yesterday but Openreach says there is an issue that could take up to 10 days to fix!! I work from home and am now panicking that my Virgin contract was due to end yesterday (still on at mo) and I'll be left without any connection at all.
I just read somewhere that EE wont instruct Virgin to disconnect until the switch is complete - does that sound right?
Solved! Go to Solution.
on 01-05-2026 02:10 PM
Yes, your old ISP's BB should not be discon'ed until your new ISP's BB is up & running.
What does BT Wholesale Broadband Availability Checker > Address Checker estimate for your address? Post the whole table, the text below it and the line above it, blanking out your address.
on 01-05-2026 04:06 PM
| 80 | 67 | 20 | 19 | 62.1 | Unavailable | Available |
| 80 | 67 | 20 | 18.7 | 60 | Unavailable | Available |
| -- | -- | -- | -- | -- | Unavailable | -- |
| Up to 1000 | Up to 220 | -- | Available | 1 Stage |
| Available |
| N |
| Y |
| N |
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG premises served by 2.5 Inch plastic duct 56.
ONT exists with active service. No spare ports are available. A new ONT may be ordered.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
01-05-2026 04:57 PM - edited 01-05-2026 04:58 PM
There's no indication of any issues there. You have an active Full Fibre service delivered from an ONT modem served by an underground duct.
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area. You may also Report a Problem there.
