Constant Disconnects & High Ping Spikes
clanc
Hi, I am currently experiencing disconnects through Wi-Fi and ethernet. I am also experiencing high ping spikes on Wi-Fi and ethernet, it's stable at 15-20ms for about 15-30 seconds then jumps from anywhere between 50ms - 150ms. This is happens on every single device that is in the house.
I have rang EE and it was said that they don't sort issues with ping as it's not down to them, I have attached me technical logs below:
18:32:49, 24 Oct. CWMP: HDM socket closed successfully.
18:32:49, 24 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
18:32:48, 24 Oct. CWMP: HDM socket opened successfully.
18:32:48, 24 Oct. CWMP: HDM socket closed successfully.
18:32:48, 24 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
18:32:48, 24 Oct. CWMP: session completed successfully
18:32:47, 24 Oct. CWMP: HDM socket opened successfully.
18:32:47, 24 Oct. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
18:32:47, 24 Oct. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 2 PERIODIC
18:32:47, 24 Oct. CWMP: Initializing transaction for event code 2 PERIODIC
17:53:49, 24 Oct. DoS(Port Scanning): IN=ppp1 OUT= MAC= src=[REMOVED] DST=[REMOVED] LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=29646 DF PROTO=TCP SPT=6098 DPT=22 WINDOW=65535 RES=0x00 URGP=0 MARK=0x8000000
17:01:28, 24 Oct. Receive a DHCP request
16:32:46, 24 Oct. CWMP: HDM socket closed successfully.
16:32:46, 24 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
16:32:46, 24 Oct. CWMP: HDM socket opened successfully.
16:32:45, 24 Oct. CWMP: HDM socket opened successfully.
16:32:45, 24 Oct. CWMP: session completed successfully
16:32:45, 24 Oct. CWMP: HDM socket closed successfully.
16:32:45, 24 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
16:32:44, 24 Oct. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
16:32:44, 24 Oct. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 2 PERIODIC
16:32:44, 24 Oct. CWMP: Initializing transaction for event code 2 PERIODIC
16:02:07, 24 Oct. A device disconnected from Ethernet port 2
16:02:07, 24 Oct. Wire Lan Port 2 down, Speed 10 Mbps
16:02:07, 24 Oct. DHCP device Disconnected: [REMOVED], [REMOVED], [REMOVED]
16:02:06, 24 Oct. LAN [DEL] ARP [REMOVED] with [REMOVED] from br0
16:02:06, 24 Oct. ARP [del] br0 [REMOVED] [REMOVED]
14:43:08, 24 Oct. NTP synchronization success
14:43:08, 24 Oct. NTP Server: ntp.hub.bt.com
14:42:55, 24 Oct. NTP synchronization start
14:33:44, 24 Oct. CWMP: HDM socket closed successfully.
14:33:44, 24 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
14:33:43, 24 Oct. CWMP: HDM socket opened successfully.
14:33:43, 24 Oct. CWMP: HDM socket closed successfully.
14:33:43, 24 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
14:33:43, 24 Oct. CWMP: session completed successfully
14:33:42, 24 Oct. CWMP: HDM socket opened successfully.
14:33:42, 24 Oct. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
14:33:42, 24 Oct. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 2 PERIODIC
14:33:42, 24 Oct. CWMP: Initializing transaction for event code 2 PERIODIC
12:33:41, 24 Oct. CWMP: HDM socket closed successfully.
12:33:41, 24 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
12:33:41, 24 Oct. CWMP: HDM socket opened successfully.
12:33:40, 24 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
12:33:40, 24 Oct. CWMP: HDM socket opened successfully.
12:33:40, 24 Oct. CWMP: session completed successfully
12:33:40, 24 Oct. CWMP: HDM socket closed successfully.
12:33:39, 24 Oct. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
12:33:39, 24 Oct. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 2 PERIODIC
12:33:39, 24 Oct. CWMP: Initializing transaction for event code 2 PERIODIC
